You should always, ALWAYS remove your chip before going to the dealer. Leaving the chip in place can interfere with the Ford diagnostic tools and makes for angry technicians. There is a very good chance that your chip is toast.
Yeah, lesson learned "OFF" might not really mean "OFF".
Can someone tell me why that switch is there then?
Off just means that the performance file is no longer active. However, the chip is still inserted into the J3 port and that is what can cause issues. It is really easy to fry the chip. If I have an issue where I'm programming a chip and I need to reboot, if I leave the chip plugged into the programmer, it's wasted. You've just got to be very careful with it, espcially if you go to the dealer.Yeah, lesson learned "OFF" might not really mean "OFF".
Thanks for all your answers.
I got the car back yesterday, turned my chip back on. And...
Well the car runs good. I don't know if it still has the correct code in it. Is there an easy way to find out?
cheers
