1 - 8 of 8 Posts
I did a "dry fire" of the solenoids, they seem to be working. The nitrous solenoid APPEARS to be louder, and when I touched it after the dry firing, it was WAY hotter than the fuel solenoid.
Andrew
You should hold your solenoids open for more than 20 seconds?! I've never heard that or done that.
Andrew
I'm sure he meant to type "shouldn't". The solenoid will overheat and burn out if you leave it on too long (unless it's designed for a 100% duty cycle).
Krunktronik Tuner Goblin
The solonoid shouldn't be held open or left pressurized for extended periods of time.
I have never had a nitrous solonoid become warm, if anything they're always cold to the touch because of the n2o flowing through them.
What brand solonoid are you running?
O .
like he said it was a dry runas in w/ no NO2 to kool it down
Discussion Starter #7
NOS :-/
I was going to do the Edelbrock conversion (Edelbrock Pro-series solenoids, the big ones, shark nozzle, bottle, and pressure gauge) but the NOS system is working admirably for me now. No issues; the heat of the N20 solenoid in the dry-fire appears to be an isolated incident.
And no, I don't hold the solenoids open for long periods of time or leave them under pressure.
Andrew
andrew, it was only hot cuz of the dry run the n2o will cool it as it is used!!! mine did it too!(NX KIT)
1 - 8 of 8 Posts
