1 - 14 of 14 Posts
hey guys when i go turbo i am getting 42lb injectors for fuel upgrade so would this maf work, i think it would web page
Should work if it's calibrated for your injector size, but it still might require some tuning to make it run right.
And you will need tuning anyway.
for what engine displacement is this thing calibrated to those injector sizes?
42# injectors on a 6 or 8 cylinder is a helluva lot more HP than 42# injectors on a 4 banger.
what are your horsepower number are you shooting for? anything under 200, an SVT focus MAF will do you fine, and anything over 200, you can get just a regular mustang GT MAF.
I believe this particular MAF is too big for your application, and you can save some trouble and coin by going OEM.
Discussion Starter #4
i need something calibrated for 42# which is what ill be using with my custom turbo kit. would a 70mm off of a mustang calibrated for 19# v8 work good with my 42's on my zetec
Discussion Starter #6
what will work, where do i buy ti and how much. ill spend the money to do it right i just need to knwo waht to get
You do NOT need the maf calibrated for any injector size. You can account for this in your tuning - both Diablo and SCT allow you to modify injector settings properly and from there it's just messing with your mass air function.
Furthermore, the aftermarket MAF sensors have a lot larger margin of error in their measurement. You would be much better off getting either a Mustang GT or a Lightning MAFS and taking care of the injector size with your tuning. You can get either of those from a junkyard or an oem reseller if you prefer brand new.
I don't recommend the lightning MAF... you have to make at least 400 HP to warrant one of those monsters.
like I said, if you're shooting for about 200WHP, an SVT MAF will do you.. if you're going slightly more than that, a Mustang GT one will do ya.
Thanks Petik. I have gotten so blue in the face from repeating that I just couldn't do it again... but after reading it on FF, again, I made it a new signature yesterday.
... anyhow, I just installed the sensor from a 90mm Lightning MAF last night. I welded a new plate to the side of my 3" intake tubing, and dropped the sensor head in - the two screws that hold the sensor head are spaced closer together on the Lightning MAF than some other Ford MAFs so I had to fab the new plate. I discarded the 90mm tube.
I will be installing some 60 pound injectors later this morning, then tuning the rest of the day.
it's all about what enclosure you end up using. i wouldn't not recommend using any oem enclosure unless you can guarantee a decent length of straight pipe before and after the enclosure so you're not getting any turbulence. i would actually recommend getting a higher resolution maf (like the lighting) and putting it in a smaller enclosure. that way you get the high precision & accuracy of the lightning maf, while still having it only go up to maybe 250whp.
Yea, I learned the hard way about how crappy the pro-m maf sensors are and will never go back to aftermarket.
So is the Lightning and Mustang GT sensor bolt pattern the same? I know the bolt pattern on my ZX3 MAFS housing is not the same as the one on the Mustang GT one - I had to fab up a housing with a lot of help from Mr JB Weld
1 - 14 of 14 Posts
