1 - 2 of 2 Posts
Eliminate side to side compliance and remove the slack in your shifter
From the factory, your manual Ford transmission shifter assembly is mounted to the body using soft rubber grommets. These OEM rubber grommets make manual shifting soft and inaccurate.
Over time, shifting gears can cause the soft rubber bushing found at the anchor point of your shifter assembly to deteriorate and fall apart. During spirited driving, these flexible rubber grommets hinder defined shifting. The solution to a rock solid shifter assembly starts with JBR Solid Shifter Base Bushings. Our machined aluminum shifter base bushings greatly reduce the chance of missing a gear and provide a much more accurate and shifting response.
JBR Solid Shifter Base Bushings are CAD designed and precision machined for exacting fitment; Made from billet aluminum for a long everlasting durability
Installation instructions can be found online in our support section.
1 - 2 of 2 Posts
