1 - 5 of 5 Posts
Right now, i have the flowmaster flex back system. It is 2in diamter piping. I plan on getting FR Stage 2 cams in the very near future and I am also looking to increast the pipe diamter with a new flex back system.
My question is, should i go with 2 1/4 or 2 1/2 inch pipe? Or, could i stay with the 2in flowmaster setup and not worry about it? Will there be any gain if i switch to the larger diameter? I figured with the stage 2 cams a bigger exhaust will help a little.
I know, on a stock engine, 2 1/4 is better due to back pressure, but since I am adding cams, i was not sure what to do.
2.25 is good for all motor builds. and its not good for "back pressure" its good due to flow velocity.
I'd agree on the 2.25. The Flowmaster uses about a 36 inch section of stock headpipe(after the flex) and could be a bit small. Too bad Flowmaster didn't partcipate in the exhaust shootout since it would have had the smallest pipe diameter tested.
1 - 5 of 5 Posts
