nevermind
The stock JRSC kit uses the dreaded "black box" which basically just tricks the car into dumping more gas into the car at WOT. It activates when it detects boost and tells the car to add extra fuel. It's really simple "tuning" that causes a rich condition. The BBK uses a reflashed stock ECU that actually adjusts timing and fuel for the JRSC. The BBK has much closer-to-stock gas mileage and drivability.1) How good is the fuel solution? I mean, I read a few months back that, on the regular JRSC it sucked (terrible mileage). Does the re-programed chip on the BBK suck too?
New injectors yes: 30lbs2) The BBK comes with new injectors, right? What about a larger throttle body?
I have yet to hear a confirmed yes or no to the removal of the stock speed limiter. Honestly though, unless you're on a track you really won't need to worry about a 110mph limiter. I'm also unsure of the rev limiter, but I would assume they bumped it up a few rpms. If you really want to I'm sure you could add an aftermarket chip with ONLY those tunes to remove the rev/speed limiter. You might want to check with Oscar Jackson or Ray @ McNews Automotive about that.3) I read on Jackson Racing's website that the you can't use a performance chip with the re-programmed stock chip, does the re-programmed stock chip increase top speed, increase redline or anything the like?
You can pretty much do most of the normal bolt-ons. Cams and head work will definitely be a no-no with the reflashed ECU.4) How many bolt on mods can the re-programmed stock chip handle? I mean, I read that you could get MILs or drivability issuse if you do too many modifications with the re-programmed chip.
I am confirming the removal of the speed limiter...I was uhhhhhhh "out on the Bonneville Salt flats" and there is no speed limiter. The stock rev limiter is still used though.I have yet to hear a confirmed yes or no to the removal of the stock speed limiter. Honestly though, unless you're on a track you really won't need to worry about a 110mph limiter. I'm also unsure of the rev limiter, but I would assume they bumped it up a few rpms. If you really want to I'm sure you could add an aftermarket chip with ONLY those tunes to remove the rev/speed limiter. You might want to check with Oscar Jackson or Ray @ McNews Automotive about that.
I can tell you my car is running solid 14.3's all day. If someone knows how to estimate 0-60 based on a 1/4 timeslip I'd be more than willing to offer some up. By having someone time me on a watch a few times I can tell you my 0-60 is in the 6-7 second territory.How fast is a Focus with the BBK? I am not as concerned with quarter mile performance as I am with 0-60 times, but both figures would be nice. Under six seconds to 60 mph would be great, but probably very optimistic. Is under 7.0 seconds a reasonable time to hit 60?
Yes, the ECU reflash entirely replaces the black box.Does the bbk ecu reflash replace the black box? Is a 14 et possible with bbk and boltons?
