will this setup work ok, or will i loose too much boost? and is it possible to run this setup , oh yhea will i still be able to use my superchip or does this need to be reburned
I have stage 1 cams with my JRSC. You will loose bottom end boost but it kicks in hard at about 3200RPM. That's really the result of installing stage 1 cams.
I like it because once it kicks in you can feel the actual boost pull the car nicely till about 6500 rpm before fuel cut off.
