koni install ?
531 Views 3 Replies 3 Participants Last post by  djsilver
i am set on getting koni yellows with eibach springs (pro kit) does enyone have eny info on the install is it pretty straight forward like the eibach dampers or is there a few tricks.
1 - 4 of 4 Posts
Fronts are straigh forward. Rears require some washers and bumpstops to be drilled out from 8mm to 12mm.
does the koni kit come with bump stops or should i pick some up and the washers that i need can i just use p51 shims?
The existing washers need to be drilled out for use with the Koni's. You don't need to buy more but feel free to use P-51's shims if you like.
1 - 4 of 4 Posts
