1 - 4 of 4 Posts
KYB GR2\'s Any good?
are they any good?
that is all. or is there something in the same price range any good?
ARe these stiffer then stock?
Brent
Re: KYB GR2\'s Any good?
GR2s are basically factory replacement shocks/struts. Probably not any stiffer than stock.
they would be like maybe 15% stiffer than stock. However, If they ever were installed with lowering springs you might as well just throw them away. They are not made to be used with lowering springs, and doing so would more than likely void the warranty (if you care about that).
Kyb agx are made for lowering-sorings. That's the major distinction between the two.
1 - 4 of 4 Posts
