Ok...Today I went back to the dyno to finish up on my tuning. This time I decided to run air/fuel and I'm glad I did. I did a base run and at 6200 rpm my air/fuel went from 11.6 to 18+(wouldn't measure any leaner). I pulled my chip out and that fixed it(it stayed rich at WOT). I went to the dyno to try to get a little more power(@138.4whp/136.6wtq should be @145+whp,145+wtq)before I get my new cat-back. Back to the air/fuel...Once I get a good run with a good air/fuel mixture I started working with the cam gears. I found that when I retarded my exhaust,(I was already at int:-5,exh:-4)I was getting more hp and tq. The problem with this was that my air/fuel was going very lean(18+) again after 6200 rpm and this didn't matter whether I retarded or advanced my intake or exhaust. I would go lean with any further adjust- ment anywhere. What do you guys think is causing my car to go lean like that. Is it my fuel pump? I don't think my injectors would be the cause because I was only pushing 138 actual not corrected whp(its 130.3 whp and 132.8 wtq SAE corrected whp). My mods are listed in my signature. Any feedback would be greatly appreciated.
Roger
[ 02-19-2003, 08:12 PM: Message edited by: Jet powered go-cart ]
Roger
