Yeah, I am sure most of you have already replaced your lower torque mount, but I just FINALLY replaced the stock unit on my yellow 04. I can not believe the difference that it made! Although there is some vibration at the stock idle, takeoffs & shifts feel substantially more solid. Of course, this could be because the rubber in the stock unit (4yrs old & with 90k miles) was ripped to pieces- whatever limited damping that was ever provided has long since failed, with an easy 1/2" of play in any direction. If your car is getting along in miles, do this!
I used the cfm mount and it was a 1 hour job, delayed only because (1) I had to pull the bracket mount on the transmission to facilitate removal & installation (easy, once I could get some leverage to break the bolts free) and (2) I couldn't line-up the bolts in the new mount because the engine moved while I was working (my hydraulic jack "sank" a bit). Once I found a helper to adjust the engine jack while I worked with the bolts, things dropped right in.
I plan to do a few more long overdue mods over the winter, as this is about out of warranty (I didn't want to hassle with my %&$^ local Ford dealers), and this is no longer my sole daily transportation (Yamaha FZ6 used most days). Next on the list is a high-flow cat & cat-back magnaflow.....
