1 - 20 of 48 Posts
Okay, I'm a little confused here. What type of fluid are you all putting in your manual trannies? Ford calls for some 75w90 or something, and a lot of people are putting in the GM synchromesh, which is a lot closer to a 5w30. I bought some Amsoil manual tranny fluid, which is 5w30, which is the Amsoil equivalent of the GM synchromesh. Whats the real deal?
umm i hope you arnt putting that into your MTX focus. the MTX-75 needs automatic tranny fluid. not the oil. and if you go with synthetic ATF you might get easier shifts, and it smooths them out a bit.
Pron Star
Um NO it doesn't MTX stands for Manual Transaxle not an automatic. Please check the owners manual for the fluid recomendations.
Um yes, ford recomended in the 00/01 focus that they use ATF
ATF AUTOMATIC TRANSMISSION FLUID!!!!
DON'T PUT MANUAL FLUID IN IT!!!!
We all know that its a manual, but FORD decided to be [email protected]% backwards. They call for ATF in tehre MTX-75's. dispite was sounds weird, its what you need to put in it.
Synthetic would be the way to go. synthetic for everything.
I use Royal Purple in my Tranny. I now have 81,000 miles and going strong....boosted too.
actually 00-02 it was mercron 5 ATF, In 03 they switched to ford full synethic manual transmission fluid. Terry recomends the Ford syth. fluid/syth atf for the mtx75
Pron Star
Thats why you read the OWNERS MANUAL.
The lubricant to be used in your MTX-75 transmission is XT-M5-QS from Ford.
Don't know who's page this is, but it sure helped me when I changed mine: linky
Been running the XT-M5-QS for 20k miles and the tranny shifts like butter in all but the coldest conditions. Only issue, and I've had this from day one, is that when its real cold out it doesn't like going into 1st when the car is not moving.
My 2001 sure as hell didnt have ATF in ut originally. I have run Synchromesh since almost new, but recently switched to BG fully synthetic synchro-shift fluid. Hard to find unless you know a BG distributor in your area.
Scott
well dont know what you had then my fiances 01 zx3 had ATF (RED), My 00 ZX3 had ATF (RED), the used 03 tranny i bought was the manual transmission fluid (A light tan color). Go ask the dealer, the 00-02 specified Mercon V for its MTX75 then after that went to the full synthetic manual tranny fluid
Don't Call Me Gaga!
That's really odd. My 2000 ZX3 most certainly had XT-M5-QS in it from the factory. Very distinct odor and color from ATF.
I personally wouldn't put ATF in a Focus MTX-75.... I tried it, and within 5,000 miles it was shifting poorly. XT-M5-QS brought it back to normal. YMMV.
Yeh, dont know why. Maybe diff fluids for diff regions (Temp etc). Terry haines recomends Synthetic ATF or Manual Transmission Fluid based on your areas temp. I wil try to find the thread.
Discussion Starter · #14 ·
well, I went ahead and put the Amsoil manual tranny fluid in there anyways. It didn't look like ATF coming out, it had to be the Ford stuff. It was kinda dirty though, and it shifts exactly the same as it did before the swap. I'll report back in a few thousand miles...
Specialty Formulations IMO are the best. I would recommend (from experience) MTL-P for warmer climates, SynchroGlide for cooler climates. IMO these are superior to ANYTHING on the market, and are priced right! Very smooth with a firm/crisp feel. It does not even seem like the same tranny. No BS
http://www.specialtyformulations.com/index_files/Page457.htm
SynchroGlide shifts a tad easier in cooler weather. SynchroGlide shifts superbly...smooth as melted butter and a very positive/crisp feel. SynchroGlide is closest to the new Ford fluid in feel, but smoother and more crisp. Night and day.
Again, I personally prefer the slightly more firm/positive/crisp feel of MTL-P. MTL-P is also super smoooooth...They sure use slick stuff
BTW Specialty Formulations makes a product, MTFGLIDE, with the viscosity close to Mercon. The lowest viscosity of their MTL line. I haven't used it but I imagine it shifts veerrryyyy easily/smooth even in super cold weather..
Mercon V
cSt @ 100ºC 7.5
MTFGlide
Viscosity @ 100C 7.5 cSt
SynchroGlide
Viscosity @ 100 9.5 cSt
Amsoil Synthetic Synchromesh Transmission Fluid (MTF)
Viscosity @ 100°C, 9.6 cSt
MTL-P
Viscosity @ 100 C 12.5 cSt
MTL-R
Viscosity @ 100 C 14.7 cSt
Redline MTL
Viscosity @ 100 10.6
Redline MTL-90
Viscosity @ 100 15.6
Redline ATF
Viscosity @ 100 7.5
Redline ATF High Temp
Viscosity @ 100 10.0
Torco MTF
Viscosity @ 100 8.35
Torco RTF
Viscosity @ 100 14.3
GM/Chrysler Synchromesh
Viscosity @ 100 9.08
Royal Purple Synchromax®
Viscosity cSt @ 100°C 7.7
For years, the MTX 75 came with ATF with a viscosity of around cSt @100ºC 7.5. Then they "switch" to a 75W-90. Some 75W-90's have a viscosity as high as @ 100°C, cSt 16.0. Specialty Formulations 75W-90 replacement, MTL-R, has a Viscosity @ 100 C 14.7 cSt.
Approximate middle range of 75w-90...80wt, viscosity range is from 7 cSt @ 100C to 10 cSt @ 100C....
I have used in my sons Focus or have driven Foci with as high a viscosity @ 100 14.3 (Torco RTF). While the Torco RTF was very good (much better than ATF, NEW Ford synthetic, and Redline), the Specialty Formulations are the best.
Again from my first hand experience, Specialty Formulations MTL-P (warmer climates like So Cal where I live) or Specialty Formulations SynchroGlide (cooler climates)is the way too go.
Don't dismiss these because you may have never heard of the company.
could be... i live in Michigan. and if i was to use gear oil (80w90) that would be so thick til it got warm. that would be nasty in our winters haha
Ummmmm.... manual tranny fluid? and you fill that where? motor oil, brake/clutch fluid, coolant, wiper fluid, power steering... nope. Don't see any tranny fluid fill cap under there.
its on the front of the tranny, it has a hex head to open it. black i think
I've been running 75w80 Syn Valvoline with no problem. My ZX3 came from the facory with ATF. Up in Michigan the shifting was difficult when below 30. But after a mile or so would shift fine.
Man, put in some Royal Purple Syncromax. Best stuff ever. Been using if for about 30,000 miles. With time the shifting has gotten almost effortless, allowing me to shifter quicker. Can't go wrong with Royal Purple. Syncromax is strickly for manual transmissions.
1 - 20 of 48 Posts
