Ok im just trying to find out if a TB design I have been machining will be of much interest to FOCUS or ZETEC owners. (No pics available til project is complete.). The Idea is simple though. The TB has a main mounting plate with three different sized bodies that can change between this main mount plate. 60mm, 65mm, and 70mm will be able to be changed in and out with out having to remove the main mounting plate. All bodies will have the same size body but have differ bore sizes, used for differ applications.
Say for a weekend at the drag you want to run a more open TB, swap in the 65 or 70 body on to the mount plate. I have described this the best I can for now. If any questions please post?
