If your buying one of the $70 ones, they actually come with a torx to remove it. O'Reillys actually sells a set of security torx by Goodwrench.....not expensive and it has all security heads (with the center drilled out) so you can use them on non-security and security head tork bolts. Whoever invented Torx should be killed...they strip so easy.
