41 - 60 of 76 Posts
Discussion Starter #41
That's pretty much what I am going to do, send it in in early December.
I have to say your RS is absolutely stunning, the upgrades tail lights and LED bulbs really set it off. Can't wait to see the end result. I think it's cool that your on the forum sharing your RS with us and answering questions. :thumbup: to you sir!
And can we get an engine shot?
Emmanuel.
Bolt on tuning kits from UK:
1) 444 Bhp + 590Nm. Pumaspeed RS 440
http://www.pumaspeed.co.uk/showdetails.jsp?productID=917
2) 404 Bhp + 408 lb/ft. BBR Focus RS Phase Four
http://www.morego.co.uk/product_details.php?id=11641&make=10&model=822
0-60: 5.3
Top Speed: 172 Mph
3) 368 Bhp + 339 lb/ft .Graham Goode GGR370FR
http://www.grahamgoode.com/website/parts.php?website=26&nav=0&item=RS370FR
4) 350 Bhp + 460 Nm. Mountune Performance Focus MP350.
0-60: 5.4 seconds
0-100: 12.2 seconds
Top Speed: 165 Mph
http://www.mountuneperformance.co.uk/index.php?option=com_content&view=article&id=171&Itemid=103
Discussion Starter #47
Mine will wipe the floor of that thing! I love WRC and I hate Energy!!
i wish u would have video of the dyno's
maybe next time?????? coming up
sweeet ride.....man
Discussion Starter #49
I do have video of the dyno runs but because the 70mph blower fan is so loud, you can't hear the engine note, which makes it kinda anticlimactic :(
Orange cones scare me
the real sad part is the idiots on that site think that this rs is owned by ford lol, dk though if the engine is a volvo or not as they say on that site
Wow wow wow. I guess I am late to this thread by about a month but the car should be ridiculous when you're all through.
Congratulations! What a gift you've been given to be able to experience having, driving, and tastefully modifying such a wonderful car!
Discussion Starter #56
Updated Mexican Focus RS Tuning Plan
Updated Mexican RS Tuning Plan
Mexican Ford Focus Baseline Dyno Run:
Baseline Wheel Power on Chassis Dyno:
298 ft-lbs at 3400 rpm
260 hp at 6000 rpm
Add back the 14% loss through the Powertrain and you have
340 ft-lbs at 3400 rpm
296 hp at 6000 rpm
Which is right on the factory spec's for power at the crank
324.5 ft-lbs at 2250 rpm
300 hp at 6000 rpm
Tuning Upgrades:
- Pumaspeed - Focus RS Mk2 Upgrade 440 Bhp
• Pumaspeed EURO Phase 5 remap/reflash - Speed limiter removed
• Full Turbo Back De-Cat Exhaust System by MILLTEK SPORT
o Milltek Sport Cat Back MotorSport Exhaust System
o Milltek Sport Decat pipe
o Milltek Sport 3 inch Down Pipe
• ITG Air Filters Maxogen CAIS
• High Power Intercooler by PRO ALLOY - BLACK version
• Bosch 650cc High Power Multi-port Injector Set
• Upgraded Phase/Stage 1 Hybrid Turbo
o Ported to a higher degree including the collector throat.
o Balanced to the ultimate tolerance
o Billet aluminum Forge actuator for higher wastegate lift
o New specification 'Cut Back' turbine wheel for higher flow
- Pumaspeed - AP Big Brake Front Kit:
• Genuine AP 6 Pot Calipers
• Genuine 362mm diameter discs
• 2 AP Racing 6 Pot dust sealed calipers
• 2 AP Racing 362 x 32 12 grooved discs
• 1 litre AP Racing dot 5.1 brake fluid
• 2 braided front brake flexy lines
• 2 Aluminum brake mounting brackets (anodized)
• 2 Aluminum bells (anodized)
• 1 set Ferrodo DS2500 brake pads
• Full fastener kit
- Pumaspeed - KW Variant 3 Coil Over Suspension kit
• 100% Stainless Steel.
• Pumaspeed have been testing the new top of the line stainless steel variant 3 fully adjustable suspension system from KW. With testing sessions on the road ,track and infamous N-ring focusing on all aspects of handling we are happy to offer the most rounded suspension system for the new Focus RS Mk2
• Lowering is adjustable anywhere from 10mm to 50mm
• KW are the Exclusive supplier to the Ford Motor Company's performance division for Ford Focus Suspension systems and components for FORD RACING !!
- Pumaspeed - High Power 6 Paddle Clutch
• Clutch to eliminate slipping over 400 bhp
• 6 paddles make for much smoother operation
• Genuine Ford cover plate from the Focus RS Mk2 2009
• Pumaspeed Sourced friction plate
• A new introduction from Pumaspeed. With power output reaching over 400 and soon the hit the 425 and with turbo kits 450 Pumaspeed have launched the New 6 paddle version clutch for the New Focus RS Mk2 2009. Built to handle power above 400bhp this unit has been designed to work with the existing hydraulic slave and Ford Dual Mass Flywheel to ensure an even smoother operation than the 5 paddle and solid flywheel versions.
- Team Torquesteer - Focus RS Sitech Intake Manifold (Green)
- Team Torquesteer - Focus RS Lower Rear Engine Torque Link (Black)
- Team Torquesteer - Focus RS Silicone Hose Kit (Green)
- Demon Tweeks - KW 20mm Wheel Spacers
- Auto Specialists - Ultimate Stainless RS Mk2 top induction pipe
Engine Dress & Exterior Upgrades:
- Team Torquesteer - Engine Compartment Dress Pro-Series Black
• Focus RS Pro-Series Black Alloy Oil Filler Cap
• Focus RS Pro-Series Black Alloy Dipstick Handle
• Focus RS Pro-Series Black Alloy Washer Bottle Top
• Focus RS Pro-Series Black Alloy Power Steering Cap Cover
• Focus RS Pro-Series Black Alloy Header Tank & Cap
- Team Torquesteer - Focus RS Daytime LED Running Lights
- Team Torquesteer - Focus RS500 Black Wheel Nuts
- Team Torquesteer - RS Door Pillar Badge
- Streamline Carbon - Ford Focus RS Mk2 Carbon Fibre Exterior Dress
• Exterior Trim Package:
o Pair of painted/carbon bonnet vents
o Grill/Hood Front trim strip
o Pair Mirror covers
• Engine Cover Set:
o Fusebox Cover
o Battery Cover
o Replacement front slam panel
• Pair Door Pillar Trims
• Pair Under Headlamp Trims
I think you should drive that thing to Ford headquarters and do burnouts in the parking lot until you get some attention then ask "WHY THE HELL DO YOU NOT PRODUCE THIS FOR THE US MARKET". Then say thank you politely, answer any questions, take some photos maybe,and drive back home.
Discussion Starter #58
Actually Ford Performance Group, the one that manages the SVT, RS, and Ford Racing groups, invited me out to the Detroit Auto Show for the new ST unveiling. Trust me they loved my Mexican RS and wanted me to bring it, but it was January so the RS stayed home warm and dry. It was the Ford US platform managers years ago that made the decision not to bring the St and RS to the US. However, in the management shakeup at Ford, it is all Europeans running the performance divisions, so whatever Europe gets the US will get as the Focus is now a global platform.
41 - 60 of 76 Posts
