1 - 7 of 7 Posts
what do i do when i use a 4 wire maf do i have to hook up a different iat sensor or is there a car that has a 6 wire 70 mm maf i can buy. any info is appreciated
If you're using an intercooler and a "suck through" setup you'll want to get an external IAT sensor. If you're using "blow through" you can just get a pro-m 70mm and be done with it.(integrated IAT)
4 wire meaning it's only a MAF without the IAT .. because the maf only requires 4 wires to operate . the other 2 wires on our stock maf are for IAT ..
reference pin #1 and pin #6:
Discussion Starter #4
do i just hardwire the 4 wire plug onto my car? how do i tell the difference from blow thorugh or suck through
instead of making a post about it what are people using for housing these days. Will the Mustang GT housing work?
yeah I have an 80mm GT maf
1 - 7 of 7 Posts
