Ok guys, pretty good news. First off, its the best damn mod for the buck, seriously. What, $17? Awesome deal you get for what it does.
Install took me a total of about 25 minutes, simple as hell. Take 3 bolts out, take bracket off. Take main bolt out of the mount and pull it out. Now you have the mount that holds the 2 bushings. The big one comes out fairly easy, a press would be nice but just hammer it out, simple. The smaller one i just drilled a few holes through it and it fell out, even better. The new ones go in even easier, take the metal piece out of the middle, put the bushing in, slide metal piece back in. Put it all back together, very simple
Performance: Foci should come with these stock. Even with my esslinger intake cam, mild, still, the vibration is minimal, and i think on a stock focus, there would be none. Either my old bushings were shot, or these things are amazing. Taking off in first gear normal driving, doesnt feel like the car is gonna bog. I think that is a big part of the bog issue, when the engine moved around before the car moved. This way, it just jumps, its awesome. Wheel hop i would say is about 60% better, none in 1st, a bit in second, but the big THUMP is gone, its just a mild skip, and only sometimes, so i am VERY VERY HAPPY> 2-3 shift doesnt feel slopy any more, you can totally feel it when you shift hard, it throws you back more, and i can now chirp 3rd, so i think that before on my 2-3 shift, the engine moved around alot instead of putting power to the tire, its awesome.
I knew that they were gonna work when i took the stock ones out. You can move the whole damn engine around like 6" in each direction without the bracket on, these 2 bushings pretty much control most engine movement, seriously, install them and see what i mean. Plus the stock ones, not only crappy rubber, but they arent solid, there are spaced in between them to let them flex even more.
OVERALL> 11/10, simply because for $17, it makes a HUGE difference in driving your car, especially if you drive it a bit hard
