1 - 3 of 3 Posts
Since the adition of the fuel on my turbo'd zx3 I have been having the problem where my stock bushings arnt worth a damn, so Ive been looking at buying poly mounts. I saw some, i guess it was on new edge website, just the mounts for like $17, then i saw the z engineering piece which is $100. My question is if I just replace the stock bushings on the mount with poly ones, isn't it pretty much the same as the z engineering iece?
yes it is basicly the same, some poeple say they feel different. I have the energy suspension mounts and they work fine for me.
Derf,
You are correct. However, some customers like to be able to change their cars back to stock for various reasons. I do not believe that you could put your rubber bushings back in after they are pressed out.(They usually tear as part of the removal process). With the Zee Engineering mount, you just swap out the "dogbone" as an assembly.
Plus the Zee Engineering piece is very sexy looking.
I have both the Zee Engineering mount and the Prothane bushings in stock.
Hope this helps.
Tony D
New Edge Performance
1 - 3 of 3 Posts
