I just got a OEM RS wing from Germany. The guy I bought it from cut the mounting bolt pieces off so he wouldn't have to drill holes in his hatch. Anyone know a good way to mount it so it won't fall off? Thanks. Sorry if this has already posted.
King of the Fairies
maybe a strong adhesive? or try to drill out the cut bolts
There are 2 studs that hold it on. What i did was fit my own studs and used epoxi to hold them in place. They are long enough to attach a washer and nut on the other side. When i mounted it i also used double sided tape. Ill get some pics for ya.
[FJ] Special Ed.
sine this is w ing, I suggest you just glue the whole kit-n-kaboodle on the car. it takes a lot for a wing to be damaged, like if someone rips it off the car. and if I wing is held on with flimsy 2faced tape, it will be easy to rip off and walk away with.
