While I've never had problems with the engine on my car, my transmission has always seemed to have issues. From when my clutch initially failed to now.
I was giving a friend a ride in my car the other day and he asked me how the new tires held up compared to the Falkens I had on before. I told him the tires held good but I could get them to chirp a bit into second. I gave it gas after a corner to show him and as I shift heard an awful grinding noise trying to shift into 3rd. Of course these problems only ever occur with someone in the car.
At this point, I have 2nd, 4th, and reverse but can't shift the car into 1st, 3rd, or 5th. I checked the transmission cables where they attach to the shifter and transmission and both seem okay. About 3 weeks ago I had one of the shifter cables pop off of the transmission so I though this was the problem initially. After talking with Noresull he suggested trying to make an adjustment to the cables by holding in the orange tabs and adjusting the tower (best way I can describe it) for the forward and backward shifter motion.
This didn't seem to provide the solution I was going for so I unhooked the cable from the transmission and tried to manually put it into gear. It will move to that position but still grinds as if it's close but just not far enough to actually go into gear.
A couple other things I've noticed is the shifter goes into Reverse before actually coming to the reverse lockout as if the cable isn't adjusted properly. (this is why I initially tried using the orange tabs) While trying to shift it's as if something is blocking me from going the extra distance I need to put the transmission into gear.
Initially driving the car like this the clutch pedal felt fine but last night when I drove it, it feels more spongy.
This car is my first manual and even though I've driven it for 2.5 years, shifting at high RPMS did occasionally grind the gears. When I first started driving the car, I did this bad a couple times. Ever since then occasionally the gears grind as if something has been bent/broken. Driving other Foci and other cars with manuals though I never grind any gears, driving normally or aggressively which leads me to believe that something has been bad from my learning on the transmission and was getting worse as time progressed.
I'm going to climb under the car after work again today but wanted to see if anyone had any suggestions for things I can test but I'm afraid I'm running out of options. I'm planning on checking the transmission fluid to see if that's low but other than that I can't think of anything else short of pulling the transmission off.
So any ideas / comments on what the problem may be?
