1 - 7 of 7 Posts
Once I have installed my sportlines and pro dampers, My 17's where wearing bad on the inside on the back, so then I got it aligned and put my stock 15's back on for now.
Now I have noticed that in the of my back tires are wearing first I check the pressure it said 30psi and tires call for 36. It doesn't make sense to me, I would think that the tires where over inflated but they are 6 PSI lower than what the tire calls for.
Any body have any Ideas.
The alignment shop said I did not need a camber kit. But who knows.
any info would be greatly appreciated.
Discussion Starter #2
sorry forget the word center. In center of the tires is where they are wearing.
Excess wear in the center of the tire is a sign of over-inflation. verify you are getting a good reading from your tire gauge. Ask your tire pro to check it for you or just get another tire gauge and check them against one another.
You might also wanna take it easy on the drifting for a while...
The wear your seeing is most likely due to the lowering of the car, a camber kit will help. Although the alignment shop say's it's OK a camber kit should help your situation. Ford has a pretty broad spec's on the alignment, so it may be within specs but at the the outer end of the parameters. I dropped both of our Foci the exact same amount and both checks within specs, but mine wore the tires out on the inside but Kathy's did fine.
Discussion Starter #6
ok great maybe i will put my camber kit on. I bought it before I got it aligned in case I needed it but they said I didn't so it sits in the box in my trunk, (no good there. lol)
I have the eibach camber for the rear, any body no where I can find installation instructions for it. I have an Idea on how but just wanted to make sure. Did a search but no luck. maybe not looking hard enough though. I did the rest of the suspension myself, would like to continue with the same.
But thanks for the info guys.
Discussion Starter #7
oh yeah why put spend the money on a good suspension if your not going to fun with it. Drifting fun. Hell on brakes and tires though.
but it wouldn't explain the wear on these tires since I didn't once with these ones, YET!
1 - 7 of 7 Posts
