It sputters and backfires from under the hood I think. It is scannning that the fuel rail pressure sensor is bad and also an Air metering system code that autozone doesn't know what it means. It has been running terrible for about 2 weeks, but now it won't even go at all. I floor it and it stays around 1000 rpm and just studders. What can I do to fix it?
2001 Zetec
thanks
Jason
Not Special Enough
post the codes.
sounds like fuel pump unless the FRPS is stuck in such a way that its reading high vac all the time.
I disconnected my O2 and the car runs. Idles a little weird but it runs. Weird.
Jason
Not Special Enough
now it isnt monitering the a/f. if you lean out, the ecu wont know about it, thats always good for the rings. a better idea would be to REPLACE the O2. hell, switch it with the downstream O2.
I have an O2 coming. I ordered one quite a while ago and it never came. So I have another one coming this week sometime.
Jason
The cables aren't long enough and the plugs are different (there's a plastic key). At least on my 00 ZX3 that was the case.
