Well, on the way up to FOTB my car started to overheat on the traffic-packed 101 fwy. We all pulled over and checked it out and all seemed alright. No problems until we reached that same area on the way back and it happened a few more times. I opened the hood to inspect again and found that the fans were NOT coming on. We check a few things and all of a sudden they are working again. Great, intermittent failure. Since I don't have my fluke and test equipment with me, we continue on, watching the gauges carefully. I get it home and I suspect that the resistor assy for the fans may have a bad connection. I unplug it to find this:
Apparently the connection may have been poor, causing excessive heat or maybe the resistor pack got too damn hot. Either way, I raced to my local Ford dealer for the resistor assy. and the wiring harness for the fans. They had a new resistor assy., but the harness will be here the next morning. Total cost is $32.00 for the assy. and $60.00 for the harness. Easy fix too. Check your connections. Maybe a little dielectric grease on them too. Here is a pic of the location of said resistor assy. I have circled the area and you can see my temporary fix so that I can get to work tomorrow.
The insulation on the wire was brittle and melting as well as the rear of the plug.
