Ok so i went down to the ford dealership and had my coolant flushed, while i was down there i brought to there attention that when i press down on my clutch to shift it makes a spring type noise from the clutch so they had looked at it and they found that the bearings might be affected...so i need to go in and get it done its still under warranty! thats awesome but my friend wants me to put the focussport aluminum flywheel is it worth it? has anybody switched over to the alumnium? how are the gains? is it ok on the bearings? my friends dad said it might not be to good because of the aftermarket flywheel with the crankshaft...I need some opinions please help!!! Should i spend the $400 for the aluminum flywheel or just get the clutch work done and leave the dual mass flywheel?
