You are correct- I don't get it. I called an SCT dealer (not FSW) prior to ordering from FSW. I told them my eventual plans for a small nitrous setup. I asked if the Xcal3 allowed me to save a copy of the stock tune as a starting point to modify- I was told I could.
I then ordered the Xcal3 from FSW and never re-asked that question. I decided that FSW had been around the longest, so that would be my best bet for a canned mail order tune.
I then found out from you, that what I was told was incorrect. That's fine- I have no problem with that. It's what I get for not asking the question from who I actually ordered from or asking SCT directly.
You told me I could modify a custom file, assuming the options were open. That makes sense- although I haven't looked to see what options are open in the Randy/FSW file. COSVT said the same thing- he said I could modify the FSW tune (if the options were left open) and verify/check my changes on a dyno and/or datalogging. I understood that when you straightened me out two days ago as well as when COSVT posted today.
My question to COSVT and you (assuming you were reading this thread) was this: Assuming I can make timing changes to the FSW file, can those changes be saved as a new file? Ultimately what I would like to be able to do is to have two files with the option of either flashing a nitrous file OR flashing the file that FSW included on my Xcal3 before shipping it to me. For example: I have a resume with several bits of information that is saved on my computer (FSW file). I find a job that I would like to apply for. I edit my original resume to talor it to the job, but save it under a different file name (Nitrous file) so I still have my original (FSW file) to go back to at a later date. I don't want to have to e
If that is possible with my setup- I will go that route. If I would be better off to pay SCT or an SCT dealer for a stock file with options enabled- that's fine also. I would just like to be able to run the bottle safely and I would also like to have the FSW file available for the times that I am not planning on using the nitrous- without having to go through the hassle of changing parameters back and forth prior to flashing each time.
Sorry if I am being dense. Turning a wrench is no problem for me. Tuning, on the other hand, is something I know nothing about. I know how timing, fuel, etc, affect the engine- but I don't know how the tuners/files actually work. I just thought something like a bit of a timing change would be about as easy as it was when a ditributor cap was used. Apparently, I could be greatly mistaken.
