1 - 11 of 11 Posts
hiyas,
I'm trying to get as much advice on this as possible so please any suggestions, feel free to say them to me
I've taken off my airbox resonator and got a K&N flexi tube and attached it to the hole left by the resonator on the airbox and attached the other end to the front of the car, as seen in these pics:
There was no room to go under the engine so I went above the battery. My question is, do I have to worry about anything happening to the battery? Any things that could go wrong with this setup? I'm only new to this whole engine modding so I dont have a clue what to expect!! lol
any advice welcome
i dont see anyhting going wrong with the battery
but why would you route that hose when you have a factory snorkel doing the same thing
Ive done the same thing with good results. The only difference is that I ran the tube in front of the battery and attached it to the drivers side of the stock snorkle intake.
run the hose right behind the driver side head light there is a hole where it can get to fresh air ... and look a lot nicer
there was no room m8 to do that ! The only gap i could find was blocked by a thick electric wire
Discussion Starter #8
<font size="2" face="Verdana, Arial">the problem was that I was losing performance as the hole left by the removel of the resonator was sucking in hot air from the engine and slowing the car.
Even though the job I did today isn't the neatest, I think its done the trick cause now I have 2 cold air intakes into the airbox, I've noticed some considerable difference in acceleration
Driver > Car
is that why you have red coolant?!
behind the headlight is prolly your best option... you can move the wiring a bit to get the hose in there.
Discussion Starter #11
<font size="2" face="Verdana, Arial">must be, cause I havent touched it since I got the car
1 - 11 of 11 Posts
