Ok, first question. Was the motor from the same year or newer? Did you transfer anything over like the crankangle sensor? Injectors...?
The engine will run without the MAF connected. It will just use a base map. I still say crank angle sensor.please swap that MAF![]()
Did you have a brain fart cory???please swap that MAF![]()
