1 - 3 of 3 Posts
Pron Star
Well I have past 2 of these on the way home now. Have not looked this up on audi.de but I tell you this thet car hauls! I wish this was avalible in the US market. In sedan form this would rule. Same for the Audi A8 4.0L TDi just great cars.
These are the specs on it from the audi.uk sight:
Engine
Engine type V6 diesel engine with VTG turbocharger, DOHC; TDI direct injection.
Performance data
Displacement, cc 2967
Max. output, kW (bhp) at rpm 150(204)/4500
Max. torque, Nm at rpm 332(450)/1400-3150
Engine management Common rail direct injection, 1600 bar with piezo injectors; seven-hole injector nozzles, VTG turbocharger with intercooler; swirl and tangential intake ports, swirl port regulated; Bosch EDC-16 CP+, volume, injection start, boost pressure, EGR control; C
Exhaust emission control Air-gap insulated exhaust manifold, oxidising converters as primary and main catalytic converters, water-cooled exhaust-gas recirculation.
Driveline
Layout V6 diesel engine with VTG turbocharger, DOHC; TDI direct injection.
Clutch Single-plate dry clutch; dual-mass flywheel
Transmission 6-speed Manual gearbox, synchromesh on all gears
Suspension
Front Four-link front suspension, upper and lower wishbones, tublar anti-roll bar
Rear Independent-wheel, trapzoidal-link rear suspensionwith resiliently mounted subframe, anti-roll bar
Tyres 215/55 R16 tyres
Wheels 7J x 16 '9-arm' design alloy wheels
Brake system
Brake system Dual-circuit brake system with diagonal split, ABS/EBD and ESP with brake assist, tandem brake booster, front: ventilated discs/rear: discs
Steering
Steering Maintenance-free rack-and-pinion steering with power assistance
Weights
Unladen weight 1655 Kg
Gross weight limit 2205 Kg
Roof load limit/nose weight limit 75 Kg
unbreaked 75 Kg
at 12% gradient 1800 Kg
at 8% gradient 2000 Kg
Volumes
Luggage compartment 460/720 Litres
Fuel tank, approx. 63 Litres (approx.)
Performance data
Top speed 144 mph
Acceleration 0-100 km/h 8 Seconds
Fuel consumption
Fuel grade 51
Urban 24 mpg
Extra urban 44 mpg
Total 34 mpg
CO2 emissions 206 g/km
Insurance classes
Liability insurance 15
Comprehensive insurance 15
Partial coverage insurance 15
Pron Star
In Germany also comes in Auto and Tipo with FWS or Quattro
1 - 3 of 3 Posts
