Re: new dyno today 146whp
awesome man...ya let us know how it turns out...what gear did you do the pull in. You might see more with some adjustable cam gears too!
no. no point with the head coming off tomorrow.I'm guessing you didn't do any tuning on the cams?
gas mileage?? i get 25-30mpggood stuff man. im curious, whats your mileage?
it was done in 4th gear.146 with no adjustables, no chip, no pullies? I'm having a hard time believe this one.
HOWS THAT NOT HARD TO DO. JUST ASK ALL THE FOCUS OWNERS
THAT STOP BY DAILY, THEY CAN VERIFY IT.
How can it be the stock head if you're running Stage 3s and 4s? It definately had to be modified for clearance issues, so how is that stock?
WHAT CLEARANCE, I TRIM THE EDGE OF THE CAM LOBE SO IT DOESNT HIT THE HEAD.
Iceman with ITG cone filter? I'd like to see the numbers with the hood closed, not open.
WHAT FOR? i HAVE A RAM AIR SETUP JUST LOOK AT IT ON MY SITE.
And most importantly, what gear?
Modifying the head for clearance issues does not effect flow #'s.How can it be the stock head if you're running Stage 3s and 4s? It definately had to be modified for clearance issues, so how is that stock?
Sorry, but who does a dyno with the hood closed? Every dyno graph you've ever seen has been done with the hood open.Iceman with ITG cone filter? I'd like to see the numbers with the hood closed, not open.
CT,We tested two different cold air types, and 3 different short ram types, plus 2 different versions of a modified factory box, with the stock filter, a flat panel K&N and no filter.
We tested them for peak power with the hood up and we tested them for power loss with the hood shut and the engine hot. We also ran them at the drag strip.
When we were done we took what we learned and designed our production version that we have for sale.
The short rams all made the most power with the hood up, as expected. They also lost the most compared to their own peak with the hood closed and the engine heat soaked. But the best short ram's peak was so much higher that it still made as much power as best "cold air" intake did when heat soaked.
In other words, the gains were like this:
[these numbers are approximate, from memory. We actually did these tests 2 years ago and I am not looking at the dyno sheets right now]
Short ram: Cold +8, Heat soaked +3
Long cold air Cold +5, Heat soaked +3
We also found that the air intakes that placed the MAF electronics into the tube didn't idle as well as the ones that used the factory sensor.
Steeda tech support
