Yep, my surging is back too - after about 600 miles.
What makes your SVT any special from the rest of us?My car performs flawlessly now. Not even the slightest hint of a surge, cold or warm. I have had the update about two weeks now.
I would try to reset the computer as mentioned in a recent thread on the ECU flash and if that does not help, take it in as you probably have some other problem.
My surges started on old factory RLA6 ECU code. Then, the JRSC was installed - the SURGES became even worse. I was very excited about the new ECU update, so I took my car to have it flashed with the new ECU update right away. It seemed to fix the surges but now they are back. My CEL also came up w/JRSC. It's related to the DSI cable. The mix of JRSC and exhaust notes on my car used to be a music to my ears for the initial 2 weeks, but then the DSI craped out and now I hear some random noise on the background - DSI motor at any RPM. In two days I will be taking mine to the S/C installer to see if he can fix the DSI noise as well as CEL. Please let me know about your CEL code w/JRSC?Mine shut of on me twice on the way to work. Also, have a cel that is back. But, I am thinking it has something more to do with the S/C that was installed a few days ago. It also surges again after the S/C install. O well taking her in today and see if svtmofo (J) cant figure it out. I bet he can.
Ok cel was caused by misfires because of three of my msd towers had corosion (sp?) on the metal. Of course this made the current very low, and I had a few mis fires. I didnt even feel them. O well. I put stock coil back on, and she is running stronger than ever. I have not had a problem yet with my dsi cable throwing a code. But, good news is that there is a local tuner near me that can turn the whole intake runner motor off. rrfperformance.com Go there and have a look around, they also have shops around the US, hope one is near you. I plan on going to these people when I get larger injectors, a pulley, and mas. But, if I do throw the dsi cable code between now and then, and get that described noise you talked about, I will be going over there and have them tune it as is with larger injectors to see if they can get some more power, and get them to turn off the motor, and cel. Later on when I get the pulley and mas I will go back and get retuned. Good luck!My surges started on old factory RLA6 ECU code. Then, the JRSC was installed - the SURGES became even worse. I was very excited about the new ECU update, so I took my car to have it flashed with the new ECU update right away. It seemed to fix the surges but now they are back. My CEL also came up w/JRSC. It's related to the DSI cable. The mix of JRSC and exhaust notes on my car used to be a music to my ears for the initial 2 weeks, but then the DSI craped out and now I hear some random noise on the background - DSI motor at any RPM. In two days I will be taking mine to the S/C installer to see if he can fix the DSI noise as well as CEL. Please let me know about your CEL code w/JRSC?Mine shut of on me twice on the way to work. Also, have a cel that is back. But, I am thinking it has something more to do with the S/C that was installed a few days ago. It also surges again after the S/C install. O well taking her in today and see if svtmofo (J) cant figure it out. I bet he can.
