1 - 1 of 1 Posts
Details:
James Barone Racing, Custom Fabrication
The JBR Transmission Mount is a vertically oriented motor mount . An almost identical mount has been in production and in use on the MAZDASPEED 3 platform for over 4 years and has become the worlds most popular since it's release. This, combined with a proven design and thorough testing, the JBR Transmission Mount Mount can and will handle all the abuse you plan to throw at it. From street to strip it's the only most versatile transmission mount for the Focus ST.
We've also replaced the weak cast aluminum transmission perch with .250" plate and a 2.00" solid steel perch. The business end of the mount is constructed of .188" steel, CNC bent plate.
No corners were cut securing the two parts of the mount together either. We use ARP studs, class 8.8 and stainless steel hardware to get the job done!
If that's not enough, our Custom, Proven Polyurethane Bushings are available in your choice of 70, 80, and 88 durometers allowing you to choose the amount of stiffness you want to run without sacrificing comfort. No other manufacturer offers this many durometers to choose from!
WHY A JBR Motor Mount?
Custom Durometer Urethane Bushings
Reduced drive train slop
Better throttle response
Precise shifts
Improved 1/4 mile times
Simple Bolt-On installation
Installation instructions are available in our support section
Shipping is free in the US & our Hassle Free Lifetime Warranty is included
1 - 1 of 1 Posts
