1 - 1 of 1 Posts
Details:
Need to reduce boost air temperatures? Want to prevent unwanted knock retard? Need to safely increase timing and increase HP? Then you need to spray meth!
Now you no longer do you have to drill and tap your cold side piping or manifold. The JBR Methanol Injection Throttle Body Spacer is quickly and easily installed between the throttle body and intake manifold and everything is included. It has 4, 1/8" NPT ports and can be equipped with up to 4 injector nozzles to meet the specific needs of your build.
The JBR Methanol Injection Throttle Body Spacer is CNC machined from 6061 aluminum then a beautiful black anodized coating is applied.
Also included is one of our Thermal Insulating Throttle body gaskets! This will help to further reduce boost air temperatures and makes the JBR Methanol Injection Spacer the best value on the market.
Application:
2013 & up Ford Focus ST
2006-2013 MAZDASPEED 3/6 & CX7
Features:
  • Designed, Engineered and Manufactured in the USA
  • Black anodized finish for long-lasting corrosion-free protection
  • Thermal Insulating gasket included
The kit includes:
  • 1, Throttle Body Meth Injection Spacer
  • 1, Thermal insulating throttle body gasket ($25.00 value)
  • 4, Stainless 1/8" NPT hex plugs
  • 4, 6mm-1.0 x 60mm socket cap head bolts
  • 4, 6mm flat washers
  • Installation instructions are available in our support section
  • Shipping is free in the US & our Hassle Free Lifetime Warranty is included
1 - 1 of 1 Posts
