1 - 1 of 1 Posts
JBR Ford Focus ST Rear Adjustable Camber Arms
Details:
Rear camber arms are often overlooked when it comes to lowering until the rear tires need to be replaced after only 10k miles. Unfortunately, the stock suspension does not allow for the necessary adjustments to correct this problem.
Adjustable Rear Camber Arms correct the additional negative camber generated when a vehicle is lowered. *Not only will they aid in camber correction but, they also allow for you to add up to +/-4 degrees of camber for on the street or the track.
Constructed entirely from high strength 4130 molly steel tubing and reinforced with thick steel gussets to prevent any unwanted flex or stress. Fitted with chrome plated 4130 spherical rod ends with a nylon race, control and road feel is increased with no need to worry about any added noise.
Sold as a set because we know you don't want just one.
Application:
Focus ST 2013 and up
Link to Product Page
Features:
  • Designed, Engineered and Manufactured in the USA
  • 4130 construction
  • Powder coated for long lasting durability
JBR Rear Camber Arm Kit Includes:
1 Set of Rear Adjustable Camber Arms
Installation instructions are available in our support section
Shipping is free in the US & our Hassle Free Lifetime Warranty is included
James Barone Racing, Aftermarket Performance Parts
*Designed to work with vehicles lowered within the realistic operating limitations of the vehicle. Not designed for stancing.
1 - 1 of 1 Posts
