1 - 1 of 1 Posts
Improvements & Updates:
  • We've brought the entire manufacturing process in house which means we can offer both kits in 3 colors and at a much lower price than before!!
  • We've improved the mounting bracket. It's now constructed out of stainless steel instead of aluminum so it won't break off like some have in the past.
  • We've relocated the drain to the bottom, increased the size of the drain from 1/4" to 5/8" and added a much easier to operate drain valve. Now you'll get every last drop of goo without clogging.
  • We're now utilizing the same OEM fittings to make the connections on the Focus ST that Ford uses. We know a few have people have had trouble with the hose connection to the intake manifold we included with our previous kits and a thread will be started shortly to address that and get them replaced.
Ford Focus ST PCV Oil Catch Can Kits:
Price:
$165.00 without a check valve and $180.00 with
Application:
- 2012 & up Ford Focus ST
Features:
  • Designed and Manufactured in the USA
  • Easily installed utilizing the supplied OEM factory fittings
  • Entirely constructed out of 6061 aluminum
  • Precision TIG welding of all components
  • Large 5/8" easily operated drain valve
Includes:
  • 1 Oil catch can
  • 1 Stainless mounting bracket
  • 52" of 3/8" polyester reinforced oil, fuel and chemical resistant hose
  • 1 male and 1 female OEM quick connectors
  • 2 Stainless steel hose clamps
  • 2, 1/4-20 x 1/2 stainless bolts
  • 2, 1/4-20 nylon lock nuts
  • 10" of 5/8 drain hose
  • 3, 3/4 nylon hose clamps
  • 1, 5/8 quick drain valve
  • Check valve and fittings (Optional)
  • Installation instructions are available in our support section
  • Shipping is free in the US & our Hassle Free Lifetime Warranty is included
Ford Focus ST Valve Cover Oil Catch Can Kits:
Application:
Price:
$180.00
Features:
  • Hoses cut to length and pre-assembled
Includes:
  • 1 Oil catch can
  • 1 Angle bracket
  • 24" of 3/8" polyester reinforced oil, fuel and chemical resistant hose
  • 1 Female OEM quick connector
  • 1 Nylon barbed hose connector
  • 3, 1/4-20 x 1/2 stainless bolts
  • 3, 1/4-20 nylon lock nuts
  • 20" of 5/8 drain hose
  • 1 zip tie
1 - 1 of 1 Posts
