1 - 4 of 4 Posts
I believe my SVT shocks and struts are at the end of their line (42,000 miles). I just want to get some better perforance replacements, leaving it stock height. I haven't yet but I do want to be able to do a couple track days here and there once I can afford a used truck as a backup vehicle. Advice on replacement pieces appreciated.
Konis, or other adjustable dampers. They'll give you a bit better performance when you need it, and stock ride quality when you're just tooling around.
They'll fit on the stock springs ok? I plan on doing the swap with my roommates help using the base auto shop. Just making sure before I spend the money.
Yep. Koni Sports/Yellows will fit just fine on the stock springs. You may have to play around for a while before you find the settings you like, though.
1 - 4 of 4 Posts
