1 - 2 of 2 Posts
im planing to put nitrous on this month like a 75 shot but its not going to be any fun if i can only go 110 so is it safe to use the excaliber programmer with nitrous
You mean the Xcalibrator? It all depends on the program you use, but it's certainly possible to have a nitrous program made for your setup.
However, IMO, nitrous is the stock PCM's achilles heel because there's no way for the PCM to "know" when you're spraying. For that reason, I suggest using a J&S Safeguard to 1.) listen for knock and automatically retard the timing and 2.) automatically retard the timing either 2 or 4 degrees when the nitrous is activated.
A multi-program chip is ideal for nitrous, since it allows you to quickly change to your nitrous file. But a flasher will also work - it's just that you'll have to compromise a bit.
1 - 2 of 2 Posts
