Just recently i've been hearing some noise from the engine area. popped the hood and the noise seems to be coming from the UDP? sounds like a bearing or belt noise. has anyone had any problem like this or am I beeing a frikin idiot and hearing a normal noise?
yep, when i installed mine it sounded like a superchagerd
Seriously though, my Esslinger came with a "Gatorback" belt and that sucker hummed at revs. It's hard to tell what sound you are talking about, the engine makes all kind's of noises and your description is not exactly clear.
Good luck though,
Milan
don't worry that noise will go away..
I get the same noise from the ac compressor check valve. When I turn off my ac it goes away. Is there any long term consequences to having the ac run like that or is it fine?
