1 - 14 of 14 Posts
OEM 16\" offset
Well, I searched (and should search again/learn how to better use the search), but I'm lazy.
What is the offset of the OEM 16x6 Focus wheels?
For some reason 49mm comes to mind, but that can't be right....
Re: OEM 16\" offset
51 methinks...but not 100% sure
Re: OEM 16\" offset
I've actually been wondering as well.
Don't Call Me Gaga!
Re: OEM 16\" offset
My 16s out the garage have ET52.5 cast into the back of the spokes...
..so 52.5mm it is!
Edit: ...and while I was out there, both the 15" wagon and 15" 10-spokes are 52.5mm as well.
Re: OEM 16\" offset
5.5" backspacing, which is actually the measurement I was looking for.....
The Ford Racing 17x7's that I won at Jetfest appear to be 5 7/8ths" backspace, w/ a 47mm offset.
I wonder what troubles I may be in for if I wrap them w/ 215/40/17's in the new Azenis 615's?
I may need some front spacers to keep the tires off the struts.
I've never messed with that.
What do I need to know?
Thanks In Advance.
Re: OEM 16\" offset
Thanks In Advance.
i think that you should be fine. do you have a drop?
Re: OEM 16\" offset
H&R Race Springs = 2" drop.
Re: OEM 16\" offset
FYI, our data shows the offset for the O.E. 16 inch wheels to be 50mm's.
That seems to contradict the 52.5 posted above, taken from the actual factory casting...
Re: OEM 16\" offset
I believe the 52.5mm is indeed accurate--it is cast right on the wheel. I was guessing at 51 up above, but I knew I rememberd that it was a smidge over 50.
So Carl, you having some 47's made up then to take advantage of SCCA's gracious .25" latitude in offset?
Discussion Starter #14
Re: OEM 16\" offset
I'm not at liberty to disclose that information right now. All I can say is the wheels will be custom, and will have billet cente....opps, I've already said too much
1 - 14 of 14 Posts
