Oil control? Baffling?
448 views 5 replies 4 participants last post by  slomo94
The only thing I have had trouble with is fuel pick-up. If I run with less then3/4 of a tank my car will cut out in right had turns.. and only right hand turns.. So, I have to top it off before I get to the track.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by OmniFocus:
If you clean the filter screen and replace the pump, this problem will go away. I can run as low as 1/8 tank now after the fix.
<hr></blockquote>
Thanks,I will have to try that. The cars handling is vary unpredictable under a full load of fuel. I thought it had something to do with that fact my wife got rearended and they had to pretty much rebuild the whole rearend. But, I see a lot of people are having the same trouble.
