1 - 7 of 7 Posts
O .
is there anywhere i can get a sandwich plate that has lines for an oil cooler i scored a HUGE one off a genII turbo II rx7 but i need something to get the oil 2 and from the kooler and i don;t want to splice into a oil line any help is good danka
ummmm....there is no oil lines on a focus. And go to BAT, they have all kinds of good stuff.
Scott
yah BAT has some nice setups with built in thermostats. Well worth the price I say.
O .
Discussion Starter #4
Scott
now i feel dumb thanx though for the info kool i'll check em out
O .
ok that wasn't exactly what i was looking for i want something i can use the big oil cooler radiator
...I would suggest a bit of data first,for example...what is your max oil temp now?....how long does it take to get hot?...hot hot is it when you get on it?....Oil has an optimum temp range....and ,FWIW cold/cool oil can do as much if not more damage to an engine than overheated oil.I'd suggest some temp readongs before you go with a huge cooler...
1 - 7 of 7 Posts
