Ok I had this bad oil smell when I turned my heat on, so I changed my valve cover gasket, which was bad. It was broken in the front right behind the header. I started up my car and turned on the heat, the smell is still there but now its not as strong. Where else could my car be leaking oil from now. Also my AC compressor has oil all over the bottom of it like it was leaking out the freon oil. Can I just put the dye into my cooling system to see if that is where it is coming from? Please help me as I am tired of smelling oil.
