Ok, after the install today I drove home and had a lot of fun. No problems at all. Then the first time I turned the car off, then 20 minutes later went to start it up again it started the following symptoms. Although the car is warm the water temp gauge reads all the way to the left (cold) at idle. When I begin to move it jumps to normal temp. Then at cruising it will go between the red and normal zone. Also, I have vibration through the pedal, but I am assuming that is the throttle cables laying on the blower. Any ideas what this could be? I am dropping it off in the morning, just wonder what this could be. All of the radiator lines are free of kinks, and all sensors are pluged in. Also, getting a CEL, and it is reading one code under the "self test" mode.
