I'm considering doign this...to do so, all I need is caliper paint right? Or do I need to bleed the brakes and thus have to buy brake fluid and all that jazz...
You need high temp paint (of the color you want) and scotch bright. If you can suspend the calipers without putting a load on the brake lines you should be ok. You must also let them sit overnight. When I did mine I smoothed them out as best as I could...wiped them clean, taped everything off and then applied two coats and let them dry and put them back together the next day.
Actually I kinda half did it because I was lazy and tired that day so I gotta redo them the right way again
