I have my pectel installed. I notice that the base ignition map looks like it has too much timing for me. I was able to find some of Chris_F timing maps on the focaljet. I would really like to look at P-51 or nazthug maps. Please guys help me out if you can. I also was able to find the fuel battery voltage modifier that P-51 made.
I have the innovate LM-1 wideband to tune my a/f ratio. I have an egt gauge installed, so I can make sure the egt tempatures don't get too high. I will probably use high octane gas just to be safe. Once I get my car driveable than I will be going to the dyno. I have not turn the car on yet with the pectel. I am probably going to do some datalogging on the stock ecu before I turn on the pectel.
