1 - 10 of 10 Posts
I suggest reading up on KogboxKing's posts in the Shift-It forum. Here's a brief summary:
1.) The stock Focus diff is glass
2.) The PG puts extra stress on stock gears that are already over-stressed.
3.) If you plan to exceed 200 ft-lbs, you should upgrade to either a Quaife or Torsen ATB differential.
if you are planning on upgrading your tranny with an lsd.
My suggestion is to hit up KogBoxKing. He is one of the designers of the MTX so he knows just a lil bit about them.
I may not be cheap... but it will be the best upgrade you may ever do to your car.
Yes, do not go with the pg, the stock form of the diff is glass. Add 2 wheels getting grip and boom
Phantom "where's the grip" I had one, and it made my car push bad, and spin the tires in the corners. Bad choice
Also, after 1,000 miles I burnt my dif up
I just installed a Thorsen lsd
works very well, and It is a true lsd.
actually it's not a lsd... it's a atbd
quaife is good. Thorsen is Ford Racing.
1 - 10 of 10 Posts
