Hi everybody !!!!
I have an air/fuel and a voltmeter to install...
I found some info for both...but not sure of what i'm doing
Air/Fuel;
- purple wire to the white wire on #60 pin on the ecu...where will i find the f*****g #60 pin I don't find it !!!!!! I know it's on the ecu but where ??? At the bottom of the connector ???
- red wire to any 12v source...some suggestion please
- black wire to the ground...some suggestion here too
I don't want to pass trough the firewall...
Voltmeter
- one wire to any 12v source...
- other wire to a good ground...
Thanks in advance for your help !
the purple wire should goto the signal wier on the first 02 sensor.
Discussion Starter · #3 ·
Criss D'épais !!!
But , it's ok now !!! I have found the pin 60 !!!
So...where is pin 60 anyway? I don't see any markings on my ecu...even under the plugs.
