Ford Duratec 2.0 16v - 2001 Mondeo
CAMS:
Valve lifts quoted assume a rocker ratio of 1:1
Base circles are reduced by at least .120" to allow a shim to be used under std bucket
DURBP270 FAST ROAD Piper valve springs part no VSSDUR & spring caps part no.SC20 must be used. 1800-
6800 12 BHP 260 deg 244 deg .383"
9.73mm .348"
8.84mm 20-60
52-12 110 deg 110 deg .008" / .20mm
.010" / .25mm £175 Repro
DURBP285 ROAD / RALLY Not recommend for std ecu. Piper valve springs part no VSSDUR & spring caps part no.SC20 must be used. 2500-
7500 18 BHP 278 deg 268 deg .414"
10.52mm .406"
10.31mm 33-65
60-28 106 deg 106 deg .011" / .28mm
.015" / .38mm £175 Repro
DURBP300 RALLY Not recommend for std ecu. Piper valve springs part no VSSDUR & spring caps part no.SC20 must be used. 3000-
8000 296 deg 288 deg .460"
11.68mm .420"
10.67mm 42-74
70-38 106 deg 106 deg .010" / .25mm
.012" / .28mm £175 Repro
Spring Caps
Titanium Spring Caps
SC20 DURATEC 16V (Suit VSSDUR springs) £ 49.00
Springs
VSSDUR DURATEC 2.0 16V SINGLE 260 lb 17.80 mm 25.15 mm 37.00 mm 25.00 mm £ 91.00
Shims
Shim Kits available @ £40 per set of 16
CAMS:
9.73mm .348"
8.84mm 20-60
10.52mm .406"
10.31mm 33-65
11.68mm .420"
10.67mm 42-74
Spring Caps
Springs
Shims
