Hi, I need to start learning fuel issues now.. i've done a search but couldn't really get the exact answer...
-in what power level i should change my fuel pump and fuel injectors?
- what is the power level that the stock fuel pump and the stock fuel injectors can handle PERFECTLY (when i mean perfectly i mean there is not a single problem at all)
- and if i go and change to bigger fuel injectors, what do i need to do (coz i know i need to do something like a chip to control it right?) and what about fuel pump?
i'm asking all this is because i felt that my car is going lean at high rpm like after 5000rpm (and i'm going to dyno these few days to check the air/fuel just to make sure.. but i still wanna know the answers first... thanks a lot.
also one more question, what exactly i need to do if i found out that my car is going lean after 5000rpm? i'm running n/a not FI, i also have a diablo chip, would this problem because of the chip?
thanks a lot for your help!!
