1 - 2 of 2 Posts
So driving my 2000 zx3 today.. 28,000 miles, optima yellow top, cold air intake, kicker amp and 12" L7 amp puts out 1280 watts max and has a 100 amp fuse comming from the battery. So im driving and it decides not to upshift... whether i floor it or not nothing happens so im basically coasting. I turn off into a Veteran home and all power shuts off my power steering goes because i lose all power to the car. I start it up again and it runs really weird doesnt sound like it has enough power to it. I unhooked the amp shut the A/C off and still sounds weird. The ground terminal was a little loose. I've been wanting to get a bigger alternator. They hooked it up to a machine and its showing all amperes are peak, the battery shows a full charge. I reconnected the negative terminal and ran it and it seemed fine so far. Any suggestions anyone?! Thank you
1 - 2 of 2 Posts
