1 - 2 of 2 Posts
Just recently ive started leaking water out of the head right under the cams and cam gears. My question is...is there any plug or anything there that could have come loose? I guess its not a huge deal to swap a head but i just wanted to ask around to see if anyone had any ideas first. Thanks
Ryan
I don't think ther is any kind of a plug there. Any possibility that it's the water pump? if not that then it sounds like a possible head gasket problem and not a cracked head. If that's the case, you will have to remove the cylinder head to replace the gasket and you can then inspect the head when you pull it. Have you had an overheating event recently? How does the car run otherwise? any water in the oil or in the cylinders? Did you remove the cam cover to see exactly where the water is coming out?
1 - 2 of 2 Posts
